Hey guys,
I'm thinking of stepping up my 2nd gen to buy a 4 x 4 3rd gen. Although I know quite a bit about 2nd gen stuff, I know very little about 3rd gen trucks.
First off let me tell you that I"m looking for a 3rd gen quad cab 4 x 4, manual shift, short bed. 2500. Probably the most desirable combo's out of all trucks if I had to bet. I don't want to go the automatic route. Too expensive to make live with a bunch of power.
I am thinking that I"d like something in the 400~500hp range. This is not a race truck by any means. I just want something reliable, that when I want to get on it, that it pulls decent. My 2nd gen. I have right now is in the ~430hp range, so I'm looking for something simular. (of course a little more
My question is, how do I acomplish this goal. Is any year truck better/worse then another. Obviously the newer trucks have a higher factory rating, but honstly if I'm going to BOMB it, then does it really matter what I start with? how much power will a factory turbo make on a 3rd gen. ? My 2nd gen still has a stock hx-35 with a 16cm swap and it seems to hold up fine (280k miles!)
How about BOMBing? I've heard that these trucks dont' react as well to injectors like a 2nd gen. did. (which is good because they are a fortune for these common rail trucks!) Will a pressure box/timing/fuel box make 400hp+ without any other mods? Or am I swapping turbos at that point? Obviously a clutch is gonna be needed at that power level. But what does it take to get there?
I'd like to pick up a '03 truck, just because of cost. But if there is reason to go with a newer model, then I'll just have to bite the bullet and go for it.
By the way, is there any huge problems that these 3rd gen trucks are seeing? I won't buy another POS vp44 powered truck again, but if the 3rd gen. trucks are having some big parts failures, I'd like to know what I"m getting into.
Thanks in advance for your help guys!
Scott
Scott
