I was at that same point once...
Before you decide to get an EZ, think if you are going to want to BOMB later, and get a "major" fueling box. If you are, then you at that point i was at when I met Stefan K. of DTT. He convinced me NOT to spend around $500 for an EZ at the time, then a year later spend another $600 for the major box. I ended up buying an EDGE COMP box from him and NOT CONNECTING THE FUEL PUMP WIRE. Five months later, I STILL have not connected the wire, and cranked out 236 horsepower on the dyno, 195 with out. Also it added just over 120 ft-lbs. I am very happy with this savings that I got by skipping the EZ.
Just more food for thought,
Andrew
P. S. You must have some strong will power to not hook that "little bitty wire" up, trust me. Plus depending on how long you keep it unhooked you might earn the nickname "loose wire"
