Just had the low pressure led installed. My understanding is that it will lite up when psi is below 5. I must admit that I am mechanically challenged. But, Im pretty sure that when I put the key in the run position, that the fuel pump starts to run and supplies fuel pressure. (so the led should be off, right ?) I notice that when I put the key in the run position (not started yet) the psi led is lit. And for a fraction of a second after I start the engine, it lites (then goes off) Is that how it is supposed to work ?
