This may be old news, but if anyone wonders why Dodges rust out in the front of the roof, it's because of a brace located just behind the roof skin. I just cut the front of my roof skin off to repair the rust beneath it, and man what a surprise. It's way worse than I thought. This is about the forth Dodge truck I've repaired, in the roof area, and this is the worst one internally. It only had some rust in the drip rail about 8 inches across. But, you can see from the pics that it rusted all the way through the frame work. Something I do to stop, or all least slow this problem way down is to rust proof the inside of the roof skin. The trick is to drill 3 holes on the inside behind the brace and through it. I drill one in the center and then one between the sunvisor hole and the center hole on each side the same distance from the edge as the sunvisor holes. My 87 had this done when it was new, but still rusted because they didn't drill through the brace also. This alows you to spray rust proofing between the roof skin and the brace and hopefully stop it from ever rusting through, if it hasn't all ready. If you have clearance lights you can spray through there. I use 3M Rust Fighter I, its basically military cosmoline. To tell if yours is rusting you can push on the outside of the roof skin along the front, and if you hear a crunch noise, then you've got rust. Mine had a good half pound of flakes sandwiched in there.
