How did the dealer confirm the bad injector? Did the solenoid fail or was it a cracked tip? I've got this knocking that sounds like loose valves (overhead adjusted at 58,000, no change) or pre ignition sometimes, and others it sounds like someone is tapping on the block with a ball peen... I've got about 63,000 miles on the truck and have only had Edge EZ and then Juice for about 15,000 miles. I had the Juice off for a couple of weeks while in Ogden for the Hot program and it didn't seem "low" on power. Doesn't smoke except for a very haze at WOT (stock). Oil analysis looks good. Am I paranoid or do I have a problem? Will a FASS or other fuel system help? If this engine is just a little more noisy because of age, that's fine. In the end I want to know the symptoms that tipped you off that something was wrong. Thanks
