The reason for the inverter is because I got the temperature controller for free from work. We have process controls here and we changed out the Love controls to the Omrons for reliability reasons. Well, there were a few laying around so I appropriated one. I wanted a shutdown timer (but wanted to do it cheap 'cause I'm a tightwad). The only down side was that the Omron controller has to have an 80-240 V input to operate. Hence, the 12V to 110VAC inverter. The Omron has an internal relay, but it can only handle 1 amp of current. So I have that relay running another relay that is 35 amps. Yes, the second relay has a resistor on the switch leg. So far, all the stuff I had laying around. So I'm only into the project for about $25. If you count the inverter, $75 (had a couple laying around). If you count the whole thing, $450. So I'm getting off cheap.
I want to have the inverter running to power the Omron because the Omron has a digital temperature readout. It allows me to check the accuracy of my Isspro pyro. It's always within 25 degrees. The only downside is that they both use the same probe. But the accuracy is right on (calibrated it at work). That and the Omron will only register up to 999 degrees. But if it's accurate below that, it should be accurate above that.
As for the kill switch, I have thought about doing that. But I want to get this fixed first. Installing a kill switch would be easy. I just have to install a small switch on the switching circuit of the relay.
I will give the cord from the house thing a try. I never thought to try that to see if it is inverter related, or if it is controller related. It just never occured to me. Thanks for the good idea.
I'll let you know how things go a little later. After I try the house A/C trick.
As for using Iron Butterfly as my shutdown timer, Dodge didn't offer a turntable as an option when I bought my truck.
