I recently purchased a 01 cummins and Im loving it! Big difference from a toyota tacoma!:-laf My question is do any of you guys see a problem with using the port on the AirDog to run the sending unit for a fuel pressuse guage? Im not concerned with the dummy low psi light that most use that port for, I want to know actual pressure. I also bypassed and pulled out the OE fuel filter assembly and pump, so from that port on the AirDog forward to VP is straight 1/2 inch hose so I wouldnt think pressure at the VP would differ much than at the AirDog... what are some of your guys's thoughts?
