Use of teflon tape on fuel injection components IS NOT recommended by fuel inj. equipment manufactures. Many components are cast aluminum,such as the filter assy. on 99 MY. The tape on the pipe threads,which are tapered,provides a slick surface between the fitting and housing and the plug acts a wedge, and with a very little torque you can split the housing. They will void warrenty if this happens. Also the tape on most metal fittings is not effective. It was developed for sealing cyrogenic (extreem cold) applications such as liquid oxygen & nitrogen.
