Archived Threw Code
Archived Drive Train Trouble in College Station, TX
Archived No Heat or A/C
I posted last week re. the TPS -- - - - Turned out it was the APPS new name for the same item - - change it out and cured the failure to down shift. I now have a code of P0216 Fuel pump timing.
Whats the fix? Is it something simple or involved?
Also still looking for a Dodge dealer in the Canton Ohio area - - anybody got an idea.
Vehicle 2001 CTD automatic
Thanks,
Denny
The 0216 code usually means your VP pump is going bad. Clear the code and see if it keeps coming back. The pump costs anywhere from $900. 00 to $1500. 00 for a reman. Every once in a while you can clear the code and nothing happens after that. Usually if it keeps coming back you need a VP. When you change the VP you might as well change the lift pump too. Try everything else possible first. It may save you a lot of money if you get lucky and find something else. Do you have a fuel pressure gauge? Have you noticed any driveability problems or loss of power? That can also help you determine the problem.
Thanks cumminspwr- - - I'll go that direct ion, shure hope I don't need an injection pump.
Yes there have been some dirivability problems, the worst being loss of power in the AM or after it has been sitting 6-7 hours. There is no power/little throttle response, and then after 30 seconds it takes off like a banshee, and no trouble the rest of the day. Road power is good. (60/75 mph)
Denny
