Engine/Transmission (1994 - 1998) throttle cables
Hi All
What do you call the cable that comes from the TPS and goes down under the battery somewhere. It connects to the same bolt as the TV cable. The connector broke a:confused::confused:nd I have it wired up. Still works but needs r&r. Thanks
Yep, goes straight to the servo that is under the drivers side battery. While you are there, be sure to check the vaccum line for cracks.
