I am stuck with a throttle problem, and the truck is rapidly becoming undriveable. The throttle seems to jam, and when more foot pressure is applied, the throttle jerks over a hard spot, and then allows accelleration. I have disconnected the throttle cable, and that is working perfectly. I had the recall done on the cable ends about 2 years ago. The jamming seems to be centred on the Throttle Position Sensor. It's either the TPS, or the throttle linkage solid rods below the TPS. I know I should disconnect the rod to isolate the problem, but I am reluctant to disconnect the rod ends as I suspect they are critically adjusted for length in the slot at the rear end. However, when I hold the rod it moves smoothly to open the throttle, so I suspect the TPS. There seems to be a lot of slop, over one eigth of an inch when I waggle with ther lever at the outside end of the spring in the TPS where the lever arm is attached. Is there a bearing at that outboard end of the TPS which might have disintegrated? I spray a lot of contact cleaner in there at every oil change. Might I have washed all the grease out of a bearing, and caused its collapse? I am off the road until this is sorted, so I'd be grateful for any advice. Nick.
