Engine/Transmission (1998.5 - 2002) Throttle position sensor
Engine/Transmission (1994 - 1998) Valair Clutch, whats your view
2nd Gen Non-Engine/Transmission Driver side window quit working
I'd try an apps noise isolator/filter before i did anything big. They're cheap and take 2 min to put in. It fixed mine
There is a noise filter that I purchased for around 12. 00 works great. I have had it on for about a year now and my transmission has not hunted once since installing it. Cheapest fix there is. Believe me I have tried them all and this one was the bomb. This link provides you with a great story on the APPS problem and the link to where to obtain the part. Try it it works great for the price. You will not be sorry. Dodge Ram Cummins 24V Truck Converter Clutch Cycling Repair.
I did the APPS rewire described on suncoast converters website, mine hasnt messed up yet. I can understand the idea... clean grounds are top requirement for the TCM and ECM to talk to each other and transmission shifts and torque converter clutch lock and unlock are a function of controllers managing the ground circuits of these components... without clean grounds on everything, you have nothing that works right.
I pulled the wires going to the tps and wrapped them in aluminum backed tape then electrical ,it solved my problem . Unhook the battery when you are doing this then reset the tps. It worked great for me ,like driving a different truck. Randy (had replaced 2 of these TPS's only to find the problems returned)
I did the BD fix after about 6 months it came back. After all the attempts and about 2 years of trial and error I tried the Noise Filter I mentioned above and after a full year I have had no trouble at all. The amazing thing is not only did my hunting stop but now when I back off the accelerator my torque converter stays locked up until I hit the brake or the rpm drops below 1000. Totaly amazing. The shift pattern is predictable also. Unless I am hard on the throttle it shifts into overdrive everytime at 56 MPH without fail. I have to say it is the best $12 I have ever spent. Try the noise filter you can find the link to where to buy it at this site. Dodge Ram Cummins 24V Truck Converter Clutch Cycling Repair.
