I had a very bad situation on my hands today. Went to pass a dump truck and pulled in front of him and let off the throttle and still kept going
Now this was becoming a major problem real fast because I had another dump truck in front of that one that I was going to rear end in a hurry. I quickly jammed on the brakes but a 7000 lb truck with 700lbs of torque going to the rear wheels and the brakes were not doing diddly. I thought to put the truck in neutral but with the wot I knew the governer wouldn't hold right away and it would more than likely damage the engine due to over-revving. I then turned the ignition and cut the engine off. Problem solved. After resarting the throttle was just fine and no more problems. This is a very scary situation. You have to make split-second decisions to avoid an accident. EVERYONE PLEASE BE AWARE THAT THIS CAN HAPPEN AT ANY TIME. I am more than a little worried that this will happen again and I may not be as lucky the second time around.
