Engine/Transmission (1994 - 1998) Throttle STUCK!!
Engine/Transmission (1998.5 - 2002) high idle
Engine/Transmission (1994 - 1998) Fan belt / serpentine belt squeal
Throttle stuck full open on me the other day while driving a friends 98 12v. The pump was just put on and set up for about 500 hp. I slid the plate forward and took it out for a test drive. Once warmed up i put the petal to the floor and it didn't feel like it was running quite right so I lifted and it just kept acelerating!!! :eek: I dove on the brakes and shut the key off but that did not shut it down completely. It finally stalled when I came to a stop. I had to prime all of the lines and have someone with a board ready to block the turbo, but it finally started again. It will not hold an idle and when I give it a little throttle it starts to rev out of control. Any thoughts? Throttle cables and connections all look good. Turbo oil seals are fine, problem must be inside the pump? I just want to make sure before we go back to the company who built the pump. Thanks!
Kevin
Kevin
Who set up and phased it ????
It was one of the top 3 companies who set up pumps. I dont want to say the name as we are still not sure of the exact cause.
