Throwing 0628 and 2509 code
Engine code
new injector problems
Kilroy
Truck keeps throwing 0628 and 2509 codes, cleared with a Scan Gauge II and they come right back.
Replaced the fuel pump 2 weeks ago with a replacement from Geno's. Mechanical fuel pressure gauge shows 7 to 8 psi in regular driving and truck seems to start and run fine.
Have replaced both batteries in last 2 weeks also. Fuel filter was replaced a month ago.
P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low
P2509 ECM/PCM Power Input Signal Intermittent
I believe some codes take 50 engine start cycles to clear. Do you have the check engine light (CEL)?
How many times have you started the truck since you replaced the lift pump? If you are having no issues with the truck and its been less than 50 starts, I would give it some more time and see if they go away. You can always get a reflash at the dealer but i'm sure it won't be free. I unplugged my FCA for troubleshooting and the code appeared for quite a while but no longer does.
It could be less than 50 starts. It would still come back after clearing the code's with the scan gauge II until I get past 50 starts?
If truck is running fine, do I need to worry about these codes showing up?
Looking to leave on vacation in a week.
I think that was the code when my pump took a dive . Didnt know that it would reset its self after however many starts. Live and learn
