throwing 3 codes
PacBrake Compressor
Pullin A 3rd Gen 6 Gear ????'S
I've been searching for a code list for a 2006 cummins 5. 9L but can't find one. I just reflashed my Quadzilla Xzillaraider II and now i'm throwing three codes. It may have been from an improper initial reconnection of the module and I haven't disconnected the battery yet to try a reset. Can someone tell me what these codes mean:
1) 0069
2) 0193
3) 0237
Thanks, and if anyone has a code list, let me know.
Jeff
P0069 MAP - Manifold absolute pressure
P0193 - Fuel rail pressure sensor circuit high input
P0237 Turbocharger Boost Sensor A Circuit Low
Thanks JWash1. Are you a Dodge mechanic? Is that where you got the codes? It looks like I connected the module poorly. I drove it two more times and and the check engine light went out - didn't have to reset it.
Mopars Are Cool
Glad I could help, No, I am not a true 'Dodge Mechanic', But I am a life long 'Mopar Nut'. I have built a few mopar gassers in the past, mostly for illegal street racing, and I was an A. S. E. certified automotive mechanic specialized in engine performance, but that was some years ago. I have found that the quickest way to get an explanation for a code is to type the code into Google, or search the TDR. When doing any installation or repair, there are a couple of rules I follow, always take your time, if you rush you may have to :{ do the job twice, and always double check your work so you do not have to :{ do the job twice.
