I had a fuel leak on the main line to the injector pump on friday Never Got Below 15 psi when leaking. After i fixed the leak and bled the injectors For possible air. I drove the truck and had no power? wouldn't boost above 10 psi and would bounce in and out of power. Check the Code threw just a 1693. Took the fuel box out and drove just on motor and had the same problem. Checked all the connections on the map sensor and throttle postion sensor. Sat night i disconnected the batt. cables and let sit over night 12 -14 hours. That didn't help. Sunday night i threw a 0122 code along with the 1693. The power comes in and out when driving. Can it be a map sensor? apps? Cam Postion. I'm starting to think maybe the fuel leak soked a connection? Not sure where Help Help!!!!!
