About a year ago and many miles ago, I put on the Kore Recon lift, got it aligned, etc... all was well.
Well, several weeks ago, a friend borrrowed it, and was backing up with the wheels turn hard left and smacked the mirror on a tree, and stopped when the tree hit the front tire (so luckily didn't get the fender!).
Well, right after that, I was towing on about an 8 hour round trip, and when I got back, I noticed bad "chunky" wear on the front tires. And, the truck just doesn't seem to handle as well to me. Now, maybe this wear is the usual problem we all have with these trucks and I'm crazy about the handling... .
So, I took it to have the alignment checked. They said everything up front is in spec with no changes needed. They did note I need ball joints
But, they said the rear thrust angle is "way" out of spec. The spec was like . 20 (or . 020?) and mine was twice that (. 40 or . 040). Of course, there isn't much to adjust in the rear of our trucks.
I don't have an adjustable track bar on front with the lift, so I know my axle isn't centered. I called the alignment shop back and mentioned that, and said that will make the front and rear axles be on a different track, and asked if that could have caused the reading they saw. They claimed that was not it.
So, do I worry about this thurst angle spec? Short of unbolting the u-bolt and trying to pull the axle and rebolting, I don't know what I could do. And, even if I did that, I'd think it would find it current position again. Or is it really just a false reading because of the front track bar.
Oh, and the thrust angle doesn't explain the front tire wear and what I consider to be poor handling, but maybe I'm just crazy on that.
