I think the oil grooves go toward the front of the engine. I think if you put it on backwards, the bolt holes will not line up properly. try laying the thrust plate on the block, one way everything will look fine, if you flip it over, Line up the bolt holes, the place for the cam will be way off to one side of the cam bore. If it looks like it would work either way, you might want to get someone else Who knows. P.
