Lately the engine has been running alot rougher than normal. Usually I throw some extra stanadyne into the tank, and run it down the highway, it will clear up. Not any more. Another new development is when I go to pass on the highway it has a very noticeable miss. It is also making a new ticking noise. It is a very high pitched noise that goes away when I let off the throttle.
The truck is not low on power, (I took down a duramax the other day
) Boost and Egt readings are normal, I even recorded 20. 4 mpg on my last road trip.
I'm thinking that I have a weak injector. Will they make a ticking noise when they go bad?
My other thought is maybe the lift pump is bad. I have not checked pressure yet. I dont have a way to do it.
I hoping the tdr can lead me down the right path before I throw money at it. Thank in advance
