Some comments on DMCs comments:
By pluralizing "valve covers" DMC may be thinking we have 6 individual covers, like they have on the 12 valves. I don't think that's the case: I believe there is just one giant gasket on 24v engines.
The 2-stage injection process he's referring to is more commonly known as pilot injection: a small amount of fuel is injected at a large advance angle (say 30 degrees BTDC or so), which increases the chamber temperature. That, in turn, tends to improve the evaporation rate of the main fuel charge, which decreases delay angle (ignition lag) and rate of pressure rise significantly. Translation: engine is much quieter.
Someone correct me if I'm blowing smoke here, but I believe the ECM turns off pilot injection when the engine is really cold. I don't know exactly what "really cold" means, but it's somewhere below 66*F (which is the cutoff for the heater grids to begin their cycle).
When cold, my truck tends to sound very much like a 2nd gen truck (the 'ol washing machine full of marbles). It tends to be much quieter when I use the block heater.
Does anyone out there have a convenient way to make some engine sound recordings? I think it might help a lot of people if we could have some "sample" 3rd gen sounds (for a stock truck). We'd want: normal warm-weather idle, cold weather idle without block heater, cold weather idle with block heater, someone with the "tick", and someone without the "tick".
