Ticking noise
Oil Pressure
Turbo Question
So, earlier this week, I noticed a ticking noise when my engine is running. It almost sounds like the noise you'd get on the old chevy big blocks when they fired up cold. I took my serpentine belt off for s&g's and started the engine. Still there. The ticking noise is there, regardless if I'm driving or idling in neutral, and increases with engine rpm. At 68,000miles, I couldn't imagine the valve lash being out of adjustment, but I'm pulling my hair out trying to figure this out!#@$%!
Does anybody know the specs for valve lash on these engines? I know you have to check it cold, which wont be a problem, it's 28 degrees here right now.
It just started making the noise. Truck ran flawlessly when I bought it back in June and drove it from Springfield, Missouri, Back to Alaska. I'm going on a long road trip up north in 2 weeks for a moose hunt, and want to figure this out before I leave. I don't want it turning into something major on the side of the road, in the middle of nowhere, in the Yukon.
Help???
Thanks, Kevin
check clamp on the fuel lines going into the head (especially #4 the blue plastic clamp assembly and that particular one tends to loosen up and make a ticking noise. )
if you need a new line go to Cummings i believe its less that $60
That was it!!!! Whew! I guess I overlooked it. I thought I checked them. It was the #4 fuel line clamp. Tightened it up and tightened all of the others as well. Glad it was something simple!
Thanks!
Kevin
This could be really good timing for me. After I installed a Fluid Dampener my eng was so much more quiet that I could then hear a little tick. I didn't think too much of it but as soon as it quits raining, I'm going to check it.
yea two dealers and 9 days latter, i finally had it "fixed"
first dealer wanted to pull head, and i said hell no!! did valves, and all kinds of other crap.
finally, I sole it back went straight to Dallas dodge they charged . 5 hrs labor and i gone, and finally happy. .
(all do to that loose #4 clamp, even with me telling the tech many times to check it, many people have had the same thing. i guess its some type of harmonics. . defentally fooled a re tarted tech! lol!!)
Lol. I was on my way to check valve lash... Waaaaay more work than I wanted to do on my days off. That thing had me going for a week! Nothin a little blue loctite couldn't solve. I did it to all of them for the heck of it.
Lumpy,
Was the tick more noticeable during acceleration? I ask because in the past few days I developed a ticking type noise. I only notice it during moderate acceleration (entering the freeway etc), dont notice it so much during cruise or idle.
I had remembered reading about a ticking noise but couldnt remember the cause. I just logged on to do a search and saw your post. I will be checking mine tomorrow.
Thanks for the info
Mike
