Okay, so with 80K miles on my truck, it's time to freshen up the front end with a new track bar and tie rod end at the pitman arm. One minor problem. After 4 winters of traveling New England and Quebec's (read salty) roads, the tie rod end is frozen into the pitman arm. I've beat it about as hard as I can with a tie rod end separator, applied penetrating oil, heated it with a (propane) torch, all to no avail.
Have any of you out there ever removed the pitman arm from the steering box? I have access to a press at work, so I'm thinking that might be an option. Aside from that, the only other thing I can think of is rounding up an oxy-acetylene torch and getting the pitman arm very warm.
Thanks in advance for any insights.
Brad
Brad
