I made this problem myself, but the truck is out of commission and I'm nearing crisis. With that said, I prepped the truck last night for the levelling springs swap. Last thing I did was pop the tie rods loose at each wheel with the castle nuts on. They came loose no problem. I left them like that for the night figuring that would be better on the linkage, less strain than having them sitting on the floor pulling down on the drag link. Now the ball stud is turning in the rod end and I can't get the castle nuts off. Both sides in the same condition, spinning in the rod end whether tightening or loosening. I tried pushing the stud up in place to hold it, no luck. I could put some needle nose vice-grips below the nuts, but I'm afraid I'll damage the threads. What to do? (I thought that was the proper way to seperate them. ) Thanks,
