I have just replaced my front pads and am experiencing something which I am concerned about.....
Local Dodge dealer did not have OEM brake pads, so went to local NAPA store and purchased "the best" pad on hand. All visual indications showed front rotor and associated calipers to be in "good" condition considering 130K on truck. First removing some brake fluid from the master cylinder, I squeezed the caliper pistons as far back as possible and replaced the old pads. I wire brushed the bearing surfaces of the caliper to the mounting bracket with a power wire brush and obtained a mostly clean surface. I then lubricated these bearing surfaces with high temp caliper grease and reassambeled the brake. All went well with the brake bleed except that now the front wheels are very hard to turn by hand. It seems that the calipers are not "floating" enough to give a release to the rotor. I have not yet driven the truck as I am not sure that this condition will not result in excessive heat build-up in the rotor.
Any comments anyone???
Tom
Tom
