tim the tool man
Question on repairing holes in roof?
HX-40 Replacement
I use a 1/2" breaker bar. Even with that, I had to use a jack handle for the "gentle" leverage to break them loose. Scary, isn't it?
My memory is a little fuzzy, but I think it was a 10mm allen with a 3/8" socket driver. Be sure to lube the inserts that the bolts travel through with Silglide or equivalent to prevent caliper binding/brake drag.
Doh!
Yep all of the above will do. Wish I saw this earlier.
<hr>
Truck Bio:
Y2K+1 3500 4X4 Quad Cab 4:10:1 LSD
Powerpack By Bank's (4 inch exhaust,High ram intake,wastgate mod to 38 psi,ottomind TLC +guages,K&N) , Jakit's Front End Leveling Kit with 255/85R16 BFG http://www.bfgoodrichtires.com/ M/T's Custom Rhino Liner (see Tool Man's truck feature)DeeZee Black Diamond Plate Bed Rails And Tool Box , WAAG Side tubes with kick~outs Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. DTT~93%TC~&~VB~TC Smart controller, Mag-Hytec'sDouble Deep Trans pan,DD injectors+Van Aken+Autometer Guages. Check out Tool's Stuff#ad
