Time For Timing
'93-W350- New for Me...
transmission abnormallity?
I am advancing my pump timing within the next few days and am using a timing tool that reads in degrees, not mm. I would like to be in the 1. 4-1. 5mm range. Is this the same as 15 degrees?
Mike
Out of couriosity, what tool is that? Timing is measured with plunger travel in the head, and that's what specs are given.
You have a dial indicator marked off in degrees?
Well, the tool I was going to use is a Snap-On Lumy/Mag 2, Tach/Timing Meter. But it won't work because glow plugs are required for use. Who needs electronics anyway? I am using a dial indicator. Thanks
Let me caution you slightly...
Sometimes the TDC pin is not accurately placed. If that's teh case, you'll never be where you think you are.
I would use some method of determining true TDC first, and then go about setting the pump. The pin can be moved to the appropriate TDC point, using just a torx bit to loosen the retaining screws. It will slide back and forth quite a ways.
Thanks for the advice Power Wagon. I will be sure to use an alternative method for determining TDC. I hope mine wasn't made on a payday on Friday afternoon. I will post the results.
Mike
Thanks for the advice Power Wagon. I will be sure to use an alternative method for determining TDC. I hope mine wasn't made on a payday on Friday afternoon, if you know what I mean. I will post the results.
Mike
Yup, me too, off by about 2*
Mine was timed with a light though. A pulse sensor is used to clamp over the #1 inj. line near the injector, then that signal is sent to a timing light. (all after finding and marking TDC of course)
It seems that 14. 5-15MM is equiv. to about 15* advance.
FWIW.
Bush'
Set the timing today. It was at 1. 2mm. Idaho Diesel Tech talked me out of anything past 1. 31mm. So, that where it sets. I would be lying if I said I could tell a difference. Nothing seemed to change at all. Oh well. :rolleyes:
I also tightened up the slack in the throtal linkage. There was abouth a 32nd" gap between the high-idle at WOT. That should be good for a whopping 1-2 hp. It now revs up to 2800rpm.
Mike
Mike
Nonsense. You can run 1. 3 to 1. 8 and be ok. I would be hesitant to pass the 1. 7 range, though. Would think it a bit noisy and harsh sounding.
This isn't the opinion of a tinkerer... I worked in a shop for years. Many B engines are timed clear up to 2!
PW,
What timing setting would you recommend for my rig? It's my daily driver (at least 60 miles per day), and tows about 12K frequently also. I plan on swapping in a smaller housing soon too, leaning toward a 14. Thanks.
