Engine/Transmission (1998.5 - 2002) Time To Upgrade Injectors
2nd Gen Non-Engine/Transmission Windshield washer motor kit
Engine/Transmission (1994 - 1998) Turbo and injector install
I JUST GOT MY HANDS ON A SET OF THE EDGE JAMMERS STAGE 3 INJECTORS AND I WAS WOUNDERING IF ANYONE NOWS WERE I CAN FIND THE INSTALL DIRECTIONS. AND I WAS WOUNDERING IF ANYONE HAS DONE THESE? ARE THEY WORTH IT??? :confused::confused::confused::confused:
I've got Diesel Dynamics instructions for install and it was easy. Took me about 2 hours in my driveway. Send me your email and I'll send it to you.
Jammer 3's are nice injectors for the price. I bought mine used and am extremely happy.
John
I'm very happy with the Stage 3's that I just installed. Very streetable and easy to drive. Max boost I have seen is 36 Psi. ( I know I know anything over 34 on a HX-35 is on borrowed time). EGTs rose about 200-250 degrees over just the EZ so I'm running close to 1250. Unfortunetly all this new found power is causing my stock clutch to slip. so its time for a new clutch... and turbo... and head studs. . and fire rings...
The instructions I used can be found at Installing Larger ISB Injectors
How Much Do I Have To Worry About My Egt's. After The Install How Much Increase Will There Be, And Whats A Safe Range To Be At Overall????
Towing at GCWR you will be getting close to 1300 on long hills. Empty you've got nothing to worry about unless you have a wire tap box. Do you have any means to run more boost? If you don't you should consider a timing box.
John
