No matter what anyone may tell you from now on, know this. THERE IS NO SPEC!!!!
There, now that that's out of the way, let me explain: GM timed these engines on a dyno, moving the pump to the point where it ran "best". Since mechanical tolerances both inside and outside those engines and fuel pumps are somewhat variable, and, they use a timing chain, not gears, the real timing position will not be fixed. As the timing chain stretches, you need to move the pump ahead to compensate.
Some aftermarket service info does have timing specs, but those are generated by checking a lot of engines and averaging the settings.
Further, unless your pump is fresh and fully updated, it's not really possible to time it accurately. The timing curve is critical to finding the spot of optimum performance, and that pump's timing curve is not very reliable. By the time it has 100K miles, it's performance barely resembles anything on a spec sheet.
As for how to time it: I'd suggest you move the pump to roughly 1/16 to 1/8 advanced (opposite pump rotation... one side of the pump has a rocker lever, the pump internals rotate DOWNWARD on that rocker side - this is true of both ford - international - and gm nat aspirated engines) from the marks lining up. That's where you start. Once you have it there, and have put in a half bottle of stanadyne additive, have the engien warm and a new air filter in it... Take it and wing the snot out of it. Most engines will pour out assorted blue, gray, or black crap out the tailpipe for the first few runs against the governor. It does have a governor, so you really can't overspeed the engine.
ONce you've blown all the soot out of the engine and exhaust, you can then take it out and put it under load, a WOT run up to high speed. If you get a gray or purple haze out the tailpipe as the engine reaches the high end, retard teh timing slightly and try again. The engine should have a pretty solid diesel clatter, but should NOT sound an early PSD. If it is real quiet, advance the timing a bit, and if it's got a harsh rasping rattle when revved or idling, then retard it a bit. If the pump is working right, the injectors clean, and the engine not full of soot, there should be no smoke at all visible no matter how hard you push it. At most, a faint haze. This is not true, if someone has turned the pump up.
Now, after this entirely unscientific means of timing the engine, it usually runs the best it will. We almost never used a timing device to set the 6. 2 engine timing. It was done seat-of-the-pants, and no other setting methodology ever seemed to get as good of results than this.
ICQ 3807791 Power Wagon
www.my2kcity.com/powerwagon
Mark Koskenmaki, General Diesel Moderator
