Engine/Transmission (1998.5 - 2002) Timing boxes with redline box
2nd Gen Non-Engine/Transmission Front Sway bar bushings
2nd Gen Non-Engine/Transmission DSS Trackbar
I want to put a timing box with my redline box. I was wondering what timing box is the best to run with the RD. I here you need alot of timing for the high fuel curve. Is the edge ez the best or a catcher ecm but i hear bad thing about it.
i'm running a comp for timing with the redline, but i heard that the redline with the catcher is a very hard hitting setup
IS the edge ez the best timing box that give you the most timing to run with the redline box. If you have the redline box what are you running
not sure about the redline in particular, but i know a couple guys using diablo pucks for timing along side their fueling boxes
Question on the redline box
Could you give me a little info about the box and how do you like it. How goes it run and does it give you alot more power than comp box. Did you upgrade you valve train or running the stock one. overall any good or box info you can say about it. Thanks Scott Phone # 815 499 6336
buddy of mine hooked up a redline and it didnt work to well ,, truck would jerk alot and just didnt run the same as it did with the comp drag so they stackd them but for ****zzz and giggles they hook the comp up to a pump cover wire then they hooked the redline to the factory black wire , it work better butt still wasnt wright so after a few calls to CHIP they sent the box back and it had a crack board , so we'll c what happens next week
I run my Redline stacked with an Edge box, the truck has dynoed as high as 610 RWHP with a single charger. The Redline normally yields about 10-15 more HP than just a drag comp. Where it shines is in the RPM department. I upgraded my valvetrain with new springs, locks and titanium retainers. With some Formula 1 injectors and a little squeeze I managed 832 RWHP @ Fall Brawl 2005.
If I can answer any more questions please feel free to call 717-557-7060.
Doug
