Vaughn MacKenzie
Quick question, on 24-valve engines that have the driver side breather tube coming off the tappet cover- how do you remove the thin cover over the hole in the timing cover in order to see the TDC mark or remove the VP44? Tried prying it and twisting it a little but didn't come loose, didn't want to force it not knowing the proper way to remove it. Pulling the VP to replace the tappet cover gasket and cam position sensor. Thanks...
