Like Dan said, it its just the cover or crank seal leaking its not that big of a job. You just have to have the right tools and basic mechanic skills. If it is under warrenty, id check with the local dealer and see when they could get to it. It shouldnt be take more than half a day, especially for a decent tech. If you have to do it yourself, make sure you have a wrench to fit the fan clutch which needs to be thin and is probably the most odd tool needed. But the way i do it is to remove the fan and shroud, followed by the radiator. Then its just a matter of getting the pulleys off and all the ten mm bolts holding on the cover. It can be a little tricky putting it back on and getting the seal set right, but with a little patience can be easily done. One the cover is off, be sure to check all around the gear case for any leaks or cracks just to be sure.
