Timing gear puller for VE pump
My headlights suck
axle nut locking washer
What kind of T- bar Puller did you use to remove the VE injection pump? I have a leak on the back side of the pump, I think. I can’t see exactly were it is. I purchased a rebuilt pump from Diesel Care & Performance. www.dieselcare.net. It has no timing line on the pump, it is locked down and I hope it’s on number one. I read the owners manual on how to install it but do you have any suggestions before I take the old one out?
I have a 1992 W250 4X4 Ext-cab with 5 speed , HX 35 with 14 wastegated housing, Stan’s SS 4” exhaust, US Gear Exhaust Brake, pyro and boost gauges on a pillar. I have pods to install at the same time as the injection pump. Need a little help and also need a little more power to pull toy hauler for gold mining.
Roy Arnold
Phoenix, AZ
The timing gear puller from Autozone worsk just fine, though you have to buy your own bolts. I think mine are M8x1. 5, but I could be wrong on that.
If you want more power, read the sticky on 1st gen performance. It normally gets locked at #1 cylinder. Just make sure to put the new pump about where the old pump was, maybe a little higher, and see how you like it. If you have the stuff, find TRUE TDC, and set the timing to about 1. 5-1. 6mm
Daniel
I recommend the Snap-On/Blue Point SP 504 puller. It works for all the Dodge/Cummins injection pumps. The VE pumps and the VP-44 pumps use a woodruff key and keyway cut in the pump shaft for timing and alignment. The VE pumps have an indented line (like a chisel notch) at the outer (the one that is easy to see) mounting stud/nut on the pump housing and on the gear case to indicate the factory timing setting.
