Engine/Transmission (1998.5 - 2002) Timing Housing oil leak
Truck has a bad oil leak! Took 1. 5 gallons to cover 600 miles. The oil is hitting the fan and flying all over the place. Have had a couple mechanics look at and said that it's the timing housing leaking. One place quoted me $1100 to fix it. I know there's a ton of labor involved but i hate to spend that much on a $30 gasket. Any ideas on exactly what is involved and is it worth paying a shop?
Thanks
I had a similar leak on my truck but did not lose that much oil. I pulled the fan, rad which needed to be cleaned, and damper. It was fairly easy to get to the timing case cover. I was able to tighten about 5 bolts which hold the timing case against the front of the block. This solved the oil leak. The rate that you are losing oil I would wonder if part of the gasket between the case and block might be missing.
Stan
Are you 100% sure its not a broken case from KDP falling out? (Yes it can happen to some 24V trucks) That's a lot of oil loss for a bad gasket or loose bolts unless its about to fall off.
My '01 lost the gaskets in front of and behind the timing case. I was losing oil fast. I was stranded and needed it fixed because I did not have the down time or tools to do it myself. Let's just say that the small town I was in made some money off of me on that one. I lost the pan gasket a few years later. After losing the head gasket a couple years later I finally had enough miles on it that I got another engine. We'll see how this one does.
not 100% sure, but I've had 3 mechanics look at it and they said the gasket around the housing and didn't mention a broken housing. I'll probably end up taking it to a guy that a friend recommended, as I don't have a good place to work on it for a whole day.
thanks for the responses
