Yah, like i said, setting the valves with the valve overlap is more than reliable. If you want a timing mark, the best way i have found was to pull #1 injector, use a dial indicator and get TDC. Get some white paint and spray the balancer on both sides of the tach pickup. Get a razor blade and make a cut on both sides of the tach pickup. It is dead on, right on the money then. Then if you ever want to use a diesel timing light then, just shine it on the tach pickup and you can tell perfectly.
