Hello All,
replaced old leaky valve gaskets the other day and what better time to check valve clearance. I have the barring tool which makes life easier but found the pin to be a bit tricky. The pin moves in and out just fine but I was never able to find the "TDC hole". I ended up using the crossover method to check clearance (no adjustment needed). Anyway, I would like to learn about finding the pin hole for next time, what did I miss or ????
I viewed some video where the pin was removed , the hole lined up, and the pin installed but that seems counterproductive to the design.
thanks for any assistance.
