well i made a beginners mistake. i didnt pin the pump when i took it out i only pinned the engine. to find tdc on the pump do flip the pump pin around i put that plastic pin in until it locks for tdc? and then after that rotate ccw until dail indicator stops moving and rotate clockwise to 6. 3 for 15 degrees timing ?
also do i move it 6. 3 or 3. 1/2 i read somewhere on here that the engine moves half the speed of the pump so you cut the reading in half
any help would be great
thanks
thanks
