I am starting to wonder if the pump gear got off by a tooth somehow when i reinstalled the pump after the shop turned it up. I'm not sure how as there isn't much room for the gear to move. If the timing pin/"rod in injector hole by eye" view of TDC is accurate then 1. 65 mm timing is a bit below the original index mark on the timing case cover... I had the pump about 1/8" above that when I started. Either that or i'm doing something wrong!! turning up the fuel screws doesn't effect the timing, right?
I'll put everything back together soon and see how the engine runs.
I am starting to wonder a bit more... . when it was cold out sometimes the engine would go to start but cut off immediately... a second crank on the starter brought it to life... is that also a symptom of timing right up there the burning eyes light blue smoke??
