Timing the injection pump for da BOMB'er
Gear Lube Analysis Numbers
4x4 engaged switch
What is the recommended timing for the bombers? I am at 15. 5 currently and it runs real strong but and I am considering going higher to help with the exhaust temperatures. I have been told that 17. 5 is where I should be at with the mods I have. My truck does have the governor spring kit and the fast idle screw is cranked in. I can pull right past 4,000 rpm with no fueling cut off. #ad
1998 2500 Quad Cab, 12V, 5spd, 4x4, HD Transfer Case, 370HP Diamond B Injectors, #4 TST, 16cm2 Housing, AFC Spring Kit, BD Governor Spring Kit and other governor modifications, Walker Muffler, 285/75-16 BFG AT's, Stainless Steel Tube Steps, Reese Fifth Wheel Hitch, Leather, CD, LSD Dana 80 Rear, 60 Front, McLeod Dual Disc Clutch, Rancho RS9000 Shocks, Rancho Steering Stabilizer, ATS Exhaust Manifold, Psychotty Air Induction, BD Exhaust Brake, Enterprise Engine Delivery Valves
[This message has been edited by dieselburner (edited 05-18-2001). ]
dieselburner:
I saw that noone had responded to your
post. My 96' is "set" at about 17. 5
right now. I feel that it runs better
there than when it was at 16-16. 5.
Joe Donnelly wrote a good article on
timing (advantages/disadvanages) in
one of the prior TDR Magazines. I think
it was #29.
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
