Well, me and a friend of mine attempted to adjust timing on my 97(cpl 2174) yesterday. The original timing had slipped to around 11 degrees. We set it to 5. 0 mm of lift on TDC(16. 5 deg. ). Test drive--ran good for about 2 minutes, then started popping with white smoke, so we limped it back to the shop. Checked timing again, it had moved to about 3. 8mm of lift(10 degrees?) So we reset it again and checked AND double checked it for proper lift. Road test--ran GREAT then same thing, popping and white smoke.
Limped it back again, checked it again, it had moved to 2. 9mm lift(like 7 degrees?) It is presently still tore down as of now.
The only thing we could figure going wrong was that we didnt use the thrust washer/bearing that Dave Fritzs' directions give. We are torqueing it to 144 ft lbs and everthing seems ok, maybe we need to torque it more?
thanks, in advance
mike rector
thanks, in advance
mike rector
