2nd Gen Non-Engine/Transmission timing?
Engine/Transmission (1994 - 1998) 97 air conditioning problem
Engine/Transmission (1998.5 - 2002) Transfer Case Rear Seal
your truck is a 24v. its all electric. the timing stuff is for the 12 valve trucks. they run off a mechanical injection pump.
The above being true, of course, but if you've removed the power steering and vac pump for repair etc. doesn't the "gear" timing have to be a certain degree upond re-installation for initial set up? Not sure just trying to learn something.
