When I swapped out my VP-44 a while back. I removed and left off the rear engine hoist gadget that is mounted to the intake manifold - made it lots easier to get at and work around those rear injectors. I found out a few days ago when working on another project, that the fearsome task of getting to the IAT for servicing was also lots easier - only a couple of minutes to remove the plug and harness, then a 13/16 sparkplug socket to remove the IAT itself - piece of cake!
Here's a shot showing how visible the IAT is once that engine lift device is out of the way:
You can also see the short bolts I had threaded back into the manifold where the lifting attachment had been installed...
