Update of today ATS exhaust swap and KSB1B. Machine shop taped and threaded ATS for 1/8 NPT. This ATS has a LOT of beef to it. Follow directions from ATS. Found that needed to take the spacer bracket off the water lines by the manifold to get the lines under the ATS well. ATS provides a bracket to remount the water bracket. Exhaust gaskets were not too hard to get in. Does the little ridge on the exhaust gasket go toward the engine or toward the manifold?
KSB1B went on next. Needed to clock it, called Kurt, easy when talking to the master. Had to go get a stubby 15mm combo wrench. The nut lower right could not get with socket or long combo wrench. Stubby worked fine. Torque wrench was out of the question.
Rips 4" with Kurts KSB1B flange. Had to grind some of Rip's PDR40/16 flange to get Kurts flange over it. Remember the machine shop?, they welded the two flanges up tight. Put the down pipe on tonight and it hits the firewall blanket at one point. That is tommorrow's project.
Also turned the pipe hanger system into max adaptability. Got the 4" OEM C clamp by the muffler off the factory weld and cleaned up. Cut the rest of the hangers off and shortened them to 2" down and put a J hook on each one. Thought is to use metal perforated strapping on the J hook, around the pipe twice, back up to the J hook on the other side. Will monitor this for a wear point. Anyone see any problems with doing it this way?
Thanks, update tommorrow
Bob Weis
