Tips/tricks for removing oil filter on the 2016?
Back into the Cummins...Ordered a new 2017 Mega
Dead Pedal Update & Lemon Law
Did a search and nothing came up for the 2016's from changing the cold heater cord it looks to be almost impossible to change the canister type oil filter on this truck. Any tips or tricks since it appears at first look that it is blocked from under the truck. have had some poorly placed oil filters after the engines have been installed in the chassis in the past.
It is blocked from beneath. Some choose to remove the intake plumbing and go in from the top. I go in through the wheel well with a band type filter wrench. When it's loose place a one gallon zip lock bag around it since it must be turned on its side to remove it in that manner.
Thanks I downloaded the pdf file since I couldn't make the on line version work on my Imac. Great info I ordered the filter glove and cap so I will be ready when I get close. Only have 1000 plus currently.
