2nd Gen Non-Engine/Transmission Tire Clearance on a 2wd dually (19.5"s)
Engine/Transmission (1998.5 - 2002) Lift Pump Failure?
BCriste
I'm considering installing 19. 5" wheels and tires from dual designs on my 96' 2wd dually (I guess technically it's a 4 wheel drive since it has 4 wheels on the back???) . I wonder if anyone has the dual designs 19. 5's on their 2wd. I'm considering buying them used from another member that has them on his 4wd. The tires that are on them are 245 / 70 / 19. 5's. I know the Rickson wheels will fit with the 225's but I'm wondering if anyone has the dual designs wheels with a 2wd and if anyone has 245's on a 2wd. It appears they may hit on the back side of the plastic inner fender well splash pan which I think I could heat with a heat gun and work it back a little?? Do tires bottom on the top of the fender wells? If so can I put longer snubbers on them to limit the front end travel some? The main reason for the wheels (other than they look great) is lower highway RPM. (The truck has a 3. 54 gear; I would love a 3. 31 rear gear if someone made it. ) I know I could put an overdrive on it. but I would like the tallest tire possible for looks and function.
Thanks again guys,
Brian Criste
