I will be needing new rubber in about 10,000 miles or less. Only have about 3/16ths left to the wear bars. And with 3 different brands on the pavement, I'm not all that happy with them.
My primary concern is tire life, off road traction isn't part of the picture for the next 3-4 years. And I won't be doing any TT pulling until I retire in 2007.
What tires have you used on your dually that gave you exceptional service?
One other item. Did you practice rotation on the rear tires? If so, any particular rotation pattern? How often?
It would seem to me that if the rear duals are not rotated that they will see the highest possible life. Putting a front tire against one already running on the rear would not give equal tread pattern on the ground.
At the same time, a tire left on the front will experience edge scrub when cornering.
Thoughts?
Thoughts?
