1998. 5 Dodge 2500 Quad Cab, 4x4, NV4500 5 Speed Manual Transmission, Stock Truck; 210,000 original miles since May, 1998.
Gentlemen:
I have been reviewing the posts as to tire brands and mileage on the site and the last big post was in 2008. I have questions as to brands and mileage obtained. The mileage that I have seen indicated is all over the map.
I have been running Michelin LTX M+S tires for the last 100,000+ miles. I seem to get between 50,000 and 55,000 miles on a set of four. I rotate the tires every 6-7 thousand miles and keep the pressures correct. Wear is pretty much even from tire to tire as long as the tires are rotated. If the tires are not rotated, I will be lucky to get 35,000 miles on a set with the rears wearing out first. The stock tire that I use is 245/75/R16. The rims are original equipment stock.
Most of the driving that I do is on improved roads with modest trailer towing (5,000-6,000#). Some unimproved roads are also driven but at low speeds.
I gave up on the stock Goodyear Wrangler tires a long time ago. I usually averaged about 40,000 miles on this brand of tire but on the last set, I had two tires go bad with sidewall failures.
Question--what can I do to improve mileage? A set of four will cost nearly $950 mounted at Costco. When I see someone claim 100,000 miles with 50% tread left, I want to see the receipts and documented proof. What do they do--drive their truck while up on blocks or do they simply drive in a straight line with no turns forever? (I hear over-the-road big rigs getting 100,000 miles on rears and trailer tires but not for this truck. )
Thank you in advance.
M. Young
Fair Oaks, CA
Gentlemen:
M. Young
Fair Oaks, CA
