When anyone buys or has new tires mounted you should make sure that the "red or blue dot" on the new tire is lined up with the valve stem and on the side of the wheel with the vale stem. Not doing this will cause more weight and more rapid tire wear. The last set of tires I had mounted on a dually using this method required less than 1. 5 oz per wheel to balance the rotating mass.
This should be good for 5K plus more miles and lots of less rebalancing in the future. I use this method on my trailer tires and don't balance them and never have.
