Hooked up the new 5er today and headed to the scales. Front axle - 4550lbs Rear axle - 5300lbs 5er axles - 9000lbs. Using a formula posted a few months ago yielded tire pressures of Front - 55 psi Rear - 65 psi 5er - 70 psi. These numbers have been rounded to the higher pressure ie front actual is 53. 2 lbs. Makes sense since the maximum tire weight on truck is 3415 at 80 psi per tire. BTW,the formula was axle weight divided by # tires divided by tire rating x max psi = tire pressure.
2001 HO 6spd,Quad cab,LWB,4x4,Flame Red,all options except for leather,Westin Brushguard/Push bar,Painless wiring,Radio Shack CB,my own design CB mount,Smittybuilt nerf bars,NW Custom rocker covers,Custom built stainless rocker light bars,DeeZee bedrails,Isspro pyro and boost gauges,Jacobs ebrake,Reese 20k 5er hitch(more to come)
