I just got the beast set up with a set on BFG All Terraine KO's in 265/75-16 Load Range D (65 PSI Cold Max)
I was wondering if there are others out there who have discovered the best inflation pressure for these tires? I have got 50Lbs all around right now and every now and then I get a "bouncing" vibration on smoth pavement. I was thinking that it might be the tires are too hard for light load and start a very slight hopping rythem.
The stock Michelin LTX MS's never did this but their tread area did not seem as hard as the BFG's. They were E Load tires that I kept at about 55- 60 PSI.
As a side note it seems that all of my stock steel rims are also Bent to some degree or another! I don't do any off-roading but they were visibly out of true on the ballancing machine and required heavy applications of ballancing lead to spin even for the machine.
I would blame the rims immediately accept that this slight bouncing vibration never occurred with the stock tires on the same rims.
If there is a Tire & Rim Doctor in the house I offer myself as as a Patient. Have At It!
